Choices...
Username: Kaerfpl
Spencerport, NY USA
Post Number: 526
Alright people, I've finally saved up what I need to buy a system but, I really don't know what I want to get. Before I started looking around on the internet, I went to a local Memphis dealer and within my price range, I would be able to get two 12" Memphis PR's, the new Memphis 500.1 amplifier, and a ported enclosure that fits the PR's Specs.
Searching around online, I found some Subwoofers that im really interested:
12" FI Q x1
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=15455550a5f359b/shopdata/0020_Q/product_overview.shopscript
12" SoundStream T5-12 x1
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5372
12" Mmats P3.0 12 x1
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2159
12" MB Quart RWE-304 x1
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3170
12" RE Audio SE12 x1
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4911
12" Boston Acoustics G512-4 x1
http://www.sonicelectronix.com/item_3800_Boston+Acoustics+G512-4.html
10" Diamond Audio D610D4 x2
http://www.sonicelectronix.com/item_5354_Diamond+Audio+D610D4.html
Here are the Specs on the Memphis PR's:
http://www.sonicelectronix.com/item_3005_Memphis+15-PR124D.html
I know that this is a big list to choose from, but what im really looking for is a combination of SQ and SPL, but more SQ over SPL.
If you guys think something in the list would be a better choice than the Memphis setup, do you think you could also list an amplifier that would run good with it?
Thanks!
Username: Kaerfpl
Spencerport, NY USA
Post Number: 527
After I posted I noticed that the FI Q link breaks in the center but the whole link is there, just gotta copy and past.
Aslo, I ment to put x2 on the MB Quart Subs.
Username: 420alldaylong
Post Number: 2594
Joe Spose
What's your budget for amp/subs?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 529
total budget runs from $700-$800...depending on how much I get for my B-Day :-)
Username: Kyle_lowe
Post Number: 286
oh...i like the re se
Username: Kaerfpl
Spencerport, NY USA
Post Number: 530
Ya, I like the RE also but, I'd only have enough money for one unless I saved up awhile longer to get two, but I really don't wanna wait any longer! I plan on ordering everything probably in like 2 weeks once im done paying off some bills.
Username: Kyle_lowe
Post Number: 290
it would be worth it to save up and wait
Username: Kaerfpl
Spencerport, NY USA
Post Number: 531
Also, im not really sure if two SE's could fit in my trunk. Im sure they use a lot of space in the trunk. The car im installing it in is a 1996 Grand Prix SE.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 532
I went onto RE's web page to see the enclosure Specs for the SE and it brought up Ported and Optimal. What does it mean by Optimal?
http://www.reaudio.com/specs.html#sp_se
Username: Skibum12189
Cleveland
Post Number: 1585
optimal is the perfect size for that subwoofer....aka what size you will want to build...
i vote dual 2 ohm 10" re se's and a kicker zx1500 or a sundown sae1000 and a 12" Fi Q....both setups would sound sweet
Cleveland
Post Number: 1586
i fluckin love the look of these subs too!
http://cgi.ebay.com/2-RE-AUDIO-SE10-10-SE-SUBS-RESONANT-ENGINEERING-pair_W0QQite mZ170145488767QQihZ007QQcategoryZ3291QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
320 for the subs...
http://www.edesignaudio.com/edv2/product_info.php?products_id=372
275 for amp
if you call elemental designs and ask one of the techs to send you the best of the b-stock amps, they're good dudes and will make arrangements...
IMO thatd be a SWEET sounding 600 dollar setup
Username: Kaerfpl
Spencerport, NY USA
Post Number: 533
compairing the memphis PR's to the SE and Q, how much of a difference would there be in SPL?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 534
Ive heard a lot of good things about that amplifier. Where can I find it's Specs?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 535
Ok, I couldn't resist those 10" SE's so I bought em'! Once I get those i'll get that amp.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 447
If you are looking at the Fi Q, you should also consider the;
SSA ICON
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=193
Ascendant Audio Havoc
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=166
Username: Th3pwn3r
Post Number:...
Post Number: 4750
"If you are looking at the Fi Q, you should also consider the;
SSA ICON
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=166"
Didn't you SSA guys bash on the Low-Hz guys for doing that sort of thing?
