Mystery here whats going on?
Username: Insearchofbass
Post Number: 5506
the old box for daily tuned at 35 hz 2.50 cf. net for the auioque 2.5 12 hit 142.4 db with head unit adjustments and we built a new box 2.50 cf net tuned to 45 hz and hit 142.6 db I dont no whats up sub was firing different and port was different place but we should have gained more than .2 db
Username: Drivingreckless
DD 9515f, 147.8 db Mov...
Post Number: 3686
just b/c you tune higher doesnt mean its gunna get louder...find your cars peak frequency and then go from their..also for a burp box 2.5 is to big try 1.25cubes tuned to 6-7 hz below your cars res. freq.
Post Number: 5507
in one placement our frequency is 54 hz in another its 55 hz....as far as testing 48 hz should have the most possibilty cabin boost wise
Username: James1115
Use a simple...
Post Number: 10124
if you changed your port direction and your sub firing direction I would have to say that the direction you had first was a better position for your type of vehicle Sean.
Post Number: 5511
a follow up
https://www.ecoustics.com/electronics/forum/car-audio/367833.html
Post Number: 5512
by the way we found the best sub and port position but up above is the follow up
