Infinity or rockford? what you all think
Username: Whtieshadow
Wodbury, Mn Usa
im about to get two 12" either
Rockford Fosgate Punch P1S412(300 peak)(150rms)
or
Infinity REF1252W (1000peak)(300rms)
what one better?
UploadUpload
Username: Mrskullz1
Brooklyn, New York
Post Number: 340
are you limited to only those 2 subs?
whats ur budget? im sure we over here can get you much better stuff all within your budget
also do you have amp/wiring etc?
and if you choose to give your budget...what are u looking for? sq (sound quality?) spl (Sound pressure level...basically how LOUD the sub is) or sql (best of both worlds of sq and spl).
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1185
x2^^^^^^^^^ don't buy those subs. There is better for the money.
Wodbury, Mn Usa
my buddy gunna buy em for me so im limited to whats at best buy
i would consider the 12" alpines they got i know they good.
otherwise it wall wried up. i already have to crapy 15"subs for checkers and a crapy 1400 watt 2channel pyle amp i just want subs that actually hit ha ha
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1186
Well, you're not going to hit much with a sh*tty amp. You really should consider saving money and getting a real setup. I understand your situation, because that is what I did as well. I regret it now. How much are you going to pay for those subs?
BTW..senior at Woodbury? I graduated from Maple Grove last year...lol
Wodbury, Mn Usa
probably less that 120 for both its about 40% the shelf price.
ya im at woodbury
Username: The_image_dynamic
San Diego
Post Number: 1080
Yeah if you are limited to what they have at Worst Buy then definately get the Alpine Type-R SWR-1242D. But I have to say that their price on those is ridiculous. They have them for $225.99 when you can get the exact same woofer online for under $140.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1187
So you're only paying $120 total? I would look at Phoenix Gold ZRs on ebay. Same price and better than both of those.
If you are 100% set on those, I would go with the Infinity. However, the Alpines would be the best bet at Best But if you must buy from there.
Wodbury, Mn Usa
look at it from my point of view the two subs i have now were a joke to begin with.
they was 20 bucks each and they sound like crap anything from best buy will be better.
its pretty much these subs but not exactly.http://www.partsamerica.com/ProductDetail.aspx?MfrCode=RDM&MfrPartNumber=MSW150& CategoryCode=3083
anything would sound better
Username: Matt12490
California USA
Post Number: 2303
What's an instantaneous peak power?
Wodbury, Mn Usa
thats a good question.
it means "real crapy sub that pound like sh#t"
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1190
haha yeah I have seen those. But even so, why upgrade slightly when you can save a little more and have a kick a** system? It just seems like such a waste to buy things that are a slight upgrade. If you must buy from BB, go with Alpine first, then Infinity and Rockford.
Wodbury, Mn Usa
Post Number: 7
are the type-r extremly supperior to the swe-1242 or are those going to be about the same
SWE-1242
600W peak, 200W RMS power handling; 3/4" Santoprene surround; dual Nomex spiders
SWR-1242D
Handles 1500W peak, 500W continuous power; KEVLAR-reinforced cone; dual Nomex spiders
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1192
Yes, the Type R are much better.
Username: Clouduz
Post Number: 187
yes the R is miles better i know from experience
