NEW Ported Box PIX
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 410
Boom, i remade this box and ACTUALLY tuned it this time! 33HZ, I just hope it fill fit in my trunk. Let me know your thoughts. The top needs screwed down, and caulked around the top piece, then its done. Did someone on here say that menards sells carpet to carpet sub boxes with? Let me know, I think im gonna carpet it as well.
Username: Bernymac
Cambodian
Post Number: 2578
Nice box, is it for a pair of type r's?
Post Number: 411
it sure is
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4230
very nice work. just curious, why isnt all 4 walls of the port painted? and just a tip... you only need screws every 5-6 inches. and stay away from edges about 3 inches.
let us know if it sounds as good as it looks!
Username: Budling
Cali USofA
Post Number: 310
Yeah, way too many screws. Most people think more screws = stronger, wrong. In most cases it actually makes it weaker.
Is that 3/4 mdf or 1"?
Post Number: 413
Yea on that side there, the drill bit broke off in the hole, so i had to make another hole. Then, the screws kept going in crooked, so i had to find a new bit, but some of those holes dont have screws in them. I plan on sealing them off though.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2609
Whats the dimensions of that box? Mind if i get the plans? My friend wont get off my @ss about giving him the box plans for his type R's.. hit me up on AIM - D92Stealth
How does it sound:-)
wood filler should fill those nicly, are the screws flushed? You can put a lil filler over them to make them vanish :-)
Los Angeles, CA USA
Post Number: 12510
very nicely done. the box looks clean.
cut some strips of mdf and get rid of the corners for better airflow.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 1102
Looks good, Glad to see you chose to tune it this time around.
Username: Sheriff
Post Number: 376
Looks good man.
Username: Rovin
My 1 12 Atom...
Post Number: 11389
looks good - kinda like mine i did a few mths ago when i had my Rs
i would suggest u double baffle the front & if u can put @ least 1 brace top to bottom & front baffle to back wall - trust me it makes ALOT of difference since u get way more output from it .....
Username: Reppinqc
Charlotte, NC USA
Post Number: 337
looks nice man...good job
Post Number: 414
36"x14.5"x23" Tuned to 33HZ. 3/4" MDF. I countersank the heads of the screws, so they rest just below the surface of the wood. Thanks for your comments guys!
Username: Jkidder
Spring hill, Florida Usa
Post Number: 515
nice box bro
