Silver Member Username: AfroopuffPost Number: 400 Registered: Jan-06 | Alright, so I have 2 dual 4 ohm speakers.... and I want to wire down to 1 ohm. I have the diagram : https://www.ecoustics.com/electronics/forum/car-audio/344562.gif But my question is, how do i do that? Is there spliters involved? Do i just strip and spin them togather? For instance, the positive is wired to the positive, but then another wire needs to be taken from that and go to the amp...do i use a splitter? Do i force them all in the terminal? If any of that makes sence... haha...thanks |
Gold Member Username: J_baby15DiRtY 5oUtH ... Post Number: 1510 Registered: Feb-06 | make all 4 positives come together and go into the amp....make all 4 negatives come together and go into the negative output of the amp. u can simply strip the end of each positive and twist em together, then have one strand coming out to hook into the amp. Same with the negative. |
Gold Member Username: CarguyPost Number: 6074 Registered: Nov-04 | If they won't all fit on the speaker terminals, you can use a distribution block. For example, 8ga to 10ga. |
Silver Member Username: AfroopuffPost Number: 401 Registered: Jan-06 | so dont wire into each other like the diagram shoes...just do all four into 1 and then one into the amp? |
Gold Member Username: PitbullguyAscendant Audio Arsenals, Chicago What the phu... Post Number: 1240 Registered: Oct-06 | Bump for clarification on this....i suspect my subs were incorrectly wired by the "professional" so i wanna fix it myself, mine are also 2 dual 4ohm looking for 1ohm |
Silver Member Username: JblanfordPost Number: 721 Registered: Oct-06 | i don't understand...lol wire it just how the diagram shows you...it doesn't get any simpler than that |
Gold Member Username: PitbullguyAscendant Audio Arsenals, Chicago What the phu... Post Number: 1241 Registered: Oct-06 | guess i'm an idiot |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 969 Registered: Aug-04 | All the positives go together and all the negatives go together. |
Silver Member Username: Waterboy2289Georgia, DiRtY SoUtH ... 2 18 SX w/ ... Post Number: 206 Registered: Jan-06 | I suppose you are using a mono amp(if you're not, the wiring is still similar to this), so here is a very easy to understand diagram http://i14.tinypic.com/2ikcod4.jpg |
Silver Member Username: Waterboy2289Georgia, DiRtY SoUtH ... 2 18 SX w/ ... Post Number: 207 Registered: Jan-06 | ***better link*** http://www.imagehosting.com/show.php/454850_2dual4subs1ohm.JPG.html |
