4 8"s????
Username: Stevefrench
Post Number: 128
how would quad 8" comp-vrs sound in an ext.cab toyota, ported and tuned t 35 hertz, how will the sound quality be and will it get semi-loud? It will be run off of a RF P800.1
Steve
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6880
I have no fu*king Idea
Username: Nd4spd18
Southeast PA
Post Number: 1381
It should be ok, but really try to get 10"s if you can fit them. 8"s just don't have a lot of output.....
Username: Homegrowncam
Funky Town, TX United States
Post Number: 409
get some decent 10s and port them instead of the 8s.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1484
yeah 10"'s. and maybe something besides kicker.
Username: Stnorris
RE SX 15, IA US
Post Number: 2129
i would do 2 15 type rs instead of CVRS if it will fit, in narrow boxes but tall and long, that would be loud.
whatever size u get, id go type rs or assassins before cvrs
Username: Loudon
Post Number: 960
who says 8's dont have output?
w7 8's knock ... ive heard many solid setups with these woofers
8 inch cvrs are solid drivers for what they are ...
if u can find assassin 8s get those or wait for the new ones ...
Username: Riskyb
Post Number: 575
"w7 8's knock ... ive heard many solid setups with these woofers"
Well hes trying to put this in a pickup truck so I doubt he has the room to mount W7 8''s because of their mounting depth. The whole point of 8''s usually is to save space.
Like people say definitly try to go with 10''s.. 8''s will give you some good mid-bass but for those deeper notes your going to need bigger woofers.
Post Number: 410
Well I am sure he can fit the w7s in there if he had the sub facing up but I am sure he isnt looking to spend that much on an 8 let alone for 4 of them.
Username: Loudon
Post Number: 963
but what i dont understand is why 4? why not one 10?
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 506
how bout ss rl-i?
