Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 28 Registered: Mar-07 | What will be better four sealed 12's or two ported 15's? |
Gold Member Username: Johnfiac151.9db Dail... My wangers b... Post Number: 2148 Registered: Mar-06 | better at what? Loudness.... prolly the 2 15's, SQ, prolly the 4 sealed 12's but it all depends on the install to.. |
Gold Member Username: Johnfiac151.9db Dail... My wangers b... Post Number: 2149 Registered: Mar-06 | that being the 15's ported and 12's sealed... if the 12's were ported they can easily blow the 2 15's away.. |
Gold Member Username: Livin_loudNo HTML in h... Post Number: 1568 Registered: Jan-06 | odds are 4 12's would require more power. power = $$ |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 5435 Registered: Jun-06 | Also, do you want loud or deep? My ex-wife can get loud at times, just not deep. |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 29 Registered: Mar-07 | two mt 15's or four sx 15's |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 30 Registered: Mar-07 | BREATH TAKING thats what i want |
Gold Member Username: Livin_loudNo HTML in h... Post Number: 1573 Registered: Jan-06 | sx's are a better daily driver. the mt's are an spl speaker. depends on what your going for |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 31 Registered: Mar-07 | i hear a lot of people using the MT's for daily driving |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 5439 Registered: Jun-06 | Now you're crossing the "border" between bumpin' and slammin', which comes at a price. |
Gold Member Username: Livin_loudNo HTML in h... Post Number: 1576 Registered: Jan-06 | you can. they get loud as hell. but the sx's sound better, and is a more typical street sub. like i said, depends on what you want |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 32 Registered: Mar-07 | well i listen to nothing but rap if that matters |
Gold Member Username: Johnfiac151.9db Dail... My wangers b... Post Number: 2150 Registered: Mar-06 | breath taking..... 4 12's or 4 15's ported in a good install... will take your breath away... expeccialy the 4 MT's haha Get some SSX's they look mean to, they will smash the SX's in SPL |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 33 Registered: Mar-07 | all i have is 11.7 cubes in a camry and whats the price of the ssx's |
Gold Member Username: Livin_loudNo HTML in h... Post Number: 1577 Registered: Jan-06 | theres no way you could fit a 10+cuft box in a trunk unless it was a friggin lincoln continental or something lol. unless your talking about a wall in the back seat area... |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 35 Registered: Mar-07 | the box is going to be built inside the trunk |
Gold Member Username: Livin_loudNo HTML in h... Post Number: 1579 Registered: Jan-06 | ah i see. have fun with all that lol http://www.treoonline.com/ssx.html i don't know how much they run for really, never looked that far into treo |
Silver Member Username: NorthomahaPost Number: 252 Registered: Mar-06 | they go for $900 per 12" sub and $1000 for a 15" |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 1900 Registered: Feb-06 | i have an SSX on 1500 watts and wangs nicely... |
Silver Member Username: NorthomahaPost Number: 258 Registered: Mar-06 | how much did you pay for yours reece |
