Bxi 2006d to a BTL 12 (STOCK)
Username: Cashby
12 Fi Q
Post Number: 305
would this amp be good for a stock 12" BTL...the amp does 2000 wrms at 1 ohm
Username: Dakangofkrunk16
Earth
Post Number: 480
hifonics over rates there sht i dont no if the saem applies for stock ones but a fully loaded one needs more than 2000watts and that will not give out 2000wrms
Earth
Post Number: 481
550-1600 Watts
Username: Nyyfan13
Fi SSD USA
Post Number: 4664
their rated at 2krms but can take more easily...hifonics tends to be overrated but i think youll see more than 1600 from it at 1 ohm...also, hows your electrical system? if your gonna run 2k you shuold get a HO alt at least. personallly, i would get a different amp for that sub...why not get a fully loaded BL for that amp, they can take 1800rms daily fully loaded...both would be relativly the same price
Earth
Post Number: 485
ooops i didnt mean to rite that i canceled the post^^^^^ guess it didnt work
Username: Fi_car_audio
Hades, NV
Post Number: 120
Should do fine. Id get the pole chamfer for most daily applications... other than that you should be good to go.
Thanks...
Scott
