Bronze Member Username: Krazzyboy44Post Number: 60 Registered: May-05 | ok i have narrowed down to these choices SUBS Alpine type r (2 ported 15's or 4 sealed 12's) kicker cvx (2 ported 15's or 4 sealed 12's) (2)memphis m3 15 (2) kicker L7 15 (2)soundstream t4-15 (2)mmats p3.0 15 (2)rl-p 15 Amps (2)kicker1200x1 (2)autotek1400.1 (2)alpine mrd-m1005 (2)kicker zx1000 sundstream pca3500 hifonics colossus |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11646 Registered: Jul-05 | rlps...with the kicker1200.1's |
Silver Member Username: JoebruceU.S.A. Post Number: 469 Registered: May-04 | No,no,no sonys ftmfw!!! |
Silver Member Username: JoebruceU.S.A. Post Number: 470 Registered: May-04 | |
Gold Member Username: BernymacCambodian Post Number: 2146 Registered: Sep-04 | mmats p3.0's ftw. |
Silver Member Username: OneracistguyTWO EGG, FL USA Post Number: 407 Registered: Sep-06 | get the type r's and have mark potts build a box for 2 15s ported hes the type r pro |
Bronze Member Username: Krazzyboy44Post Number: 61 Registered: May-05 | will the soundsplintres hit harder than the L7's |
Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 564 Registered: Jun-06 | if your going for loudness im sayin Type R's no doubt but if you want some sql i'd go with the rl-p's definetly with 2 zx1000's.....yep that'd be a real nice setup! |
Bronze Member Username: Krazzyboy44Post Number: 62 Registered: May-05 | i want spl i really dont care about sq that much |
Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 565 Registered: Jun-06 | i'd still go with the rl-ps cuz im sure they will probably be just as loud and they are very nice subs, look badass too, way better than type r's |
Bronze Member Username: Krazzyboy44Post Number: 63 Registered: May-05 | will the soundsplinters have more spl than than L7's |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11647 Registered: Jul-05 | "will the soundsplinters have more spl than than L7's" Install.... |
Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 566 Registered: Jun-06 | but still with the rl-p your getting a better overall sub, im sure it has way better build quality, and is more durable than the l7 |
Bronze Member Username: Krazzyboy44Post Number: 64 Registered: May-05 | i have 4.5 per sub with two kicker kx1200.1 what the better choice |
Silver Member Username: DreamtheaterPost Number: 118 Registered: Sep-06 | rl-p ftw |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 1795 Registered: Dec-06 | Ba Boom Boom Bass! http://www.youtube.com/watch?v=oksCOUeIjYg |
