Anyone Need a Box Built??? # 3
Username: Logan__tille
Imortal Box Building
Post Number: 6053
Ported***
10" $55+shipping
12" $60+shipping
15" $65+shipping
Dual Sub Boxes
Ported***
10" $80+shipping
12" $85+shipping
15" $90+shipping
Carpet is an extra $45 on single sub boxes and $55 on dual.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 686
Do you only do slot ports or are you going to start working w/ aeros? Just kinda wondering.
Post Number: 6060
i can do aeros... it will cost more though
Username: Chrsschb
Have you ever built a box for a 1999-2004 mustang?
Post Number: 6061
nope
Username: Spkrman
Chi town, IL U S A
Post Number: 176
Mustangs are such a PITA to work in!
I've done a variety of boxes, a handful of testing... and arrived @ what works.
My advice - one 12 or 2 10's, and slide the box in from the rear seats.
Username: Chrsschb
I can't do the rear seat thing I have a convertible (If it's possible I don't know how). I would like a box for one 12 but no idea how that is going to fit inside from the trunk side.
Username: Chrsschb
Oh, I have the mach sound system also, so the amp rack is in the way (I could probably relocate it).
Username: Spkrman
Chi town, IL U S A
Post Number: 190
convertable... ouch!
i'd roll with one 10, if it were me.
Username: Impala63rag
DD 9512s , Orion d5000
Post Number: 579
https://www.ecoustics.com/electronics/forum/car-audio/324780.html
link to part 2
so I don't have search a months worth of threads
Username: Bernymac
Cambodian
Post Number: 2085
Logan, want to build me a box just like my old one. But I need it to be wider, but not as tall and not as deep. If you know how to do the calcuations and such then coo. Hit me up. And to do a box like mines you'll probaly need 3 sheets of mdf. But yeah, fasho. See sup mangs.
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 328
about how much does shipping go for? jus lookin for sum kinda range
Username: Johnfiac
IL Afghanistan,...
Post Number: 1519
Backseats always work to hold your subs tooo :-) just hope u have some dark tints all the way around so u dont get jacked.... if u dont use your backseats that is...
Midland, Texas U.S.
Post Number: 330
backseats in a mustang are pointless unless its children under 10
Username: Jesse59672
OK
Post Number: 10
Hey logan I'm wondering if you can build a box for a 99' camaro. I'm lookin for a single 12'' box with around 2.25-2.75 sq ft. I don't need it carpeted or anything just wondering if you could do it
Post Number: 6097
Depends..is it going in the little trunk space?
OK
Post Number: 13
meh i'm not sure they are hatchback you know..
it will be in the little spot closest to the rear of the car. im not sure if its 2.5 sq ft or not
Username: Jgelp7
New Orleans
Post Number: 55
Logan, I don't see where to cut the hole on the top in these plans without running into the port wood.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=36&Eh=17&Dia=9&Xmax=21&Vd= .17&NumW=1&Vb=3.5&Fb=33&Qts=&Vas=&Fs=&CE=0
Should I just cut the hole in the front and face the sub and port up? What do you suggest?
Post Number: 6120
on the front. The red line.
Username: Chrsschb
Logan you know anyone with a 1999-2004 mustang convertible? (Possibly go to a used car dealership) If you could get some measurements I would most likely buy a box from you.
12" preferred. Will settle for 10" if 12" isn't possible. The box has to be able to slide into/out of the trunk (not through the seats).
Thanks.
Username: Chrsschb
Actually, nevermind. I need to find a way to put a box in the cabin. A convertible's trunk isn't very friendly to bass.
Post Number: 6134
put it in the back seat
Username: Chrsschb
I have a box in the backseat right now, but I have to remove it any time I have to use the car seat. Trying to get something more permanent =)
Username: Bump05
CashMoney, 15 Hd3 USA
Post Number: 974
hey forbidden someone who builds great boxes for mustangs is phil from woodlawn cabinetry. check him out hes great
Username: Bump05
Post Number: 975
woodlawn.cabinetry@verizon.net
