Wher can I get the specs and see some Havoc's??
Username: Teamdeboy1971
OPTIDRIVE LN., TN Major Bass P...
Post Number: 200
I would also like to have some audio t-shirts if anyone knows where to find them, holla?????
Post Number: 202
Ok, I may have figured out my wiring problem on my 2-10inch premiers!!! They are both 2+2DVC! OK,Here's the tricky part! If I am running the Kenwood KAC-9152D THIS Paticular amp is supposely running 1800watts well its a Dual mono drive, so my subs are not wired right! I think I need to wire them like I have 1 sub so each sub would be at 1 ohm right or wrong? see right now I have the hot and grnd from amp to one side of sub, then I have my extra wires running from red to red and black to black, however there wired I'm not sure and That amp runs best on 900wrms on each mono chanel, I thinkLMAO
Post Number: 203
Man this forum messes up alot!!!
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 542
this is like a myspace bulletin. The topic has nothing to do with the meat of the post and then your next post isnt about the first post OR the topic!!!!
Username: 54danny54
KY More Wang Th...
Post Number: 2934
well i have a havoc
www.ascendantaudio.com will have pics n specs
