Username: Kicker101 Alberta
Post Number: 53 Registered: Nov-05
Wednesday, November 01, 2006 - 01:21 GMT ( Two 12" Kicker L5's) OR (Two RE Audio 12" MX Series)?????? please compare head to head??
Username: Rvlacos DD 3512 United States
Post Number: 301 Registered: Sep-06
Wednesday, November 01, 2006 - 01:23 GMT 2 re mx 12's deffinetly. but there is better for the money imo.
Post Number: 54 Registered: Nov-05
Wednesday, November 01, 2006 - 01:49 GMT like what?
Username: Cenus 4,
20
Post Number: 2421 Registered: Jan-05
Wednesday, November 01, 2006 - 03:14 GMT ha the mx's hands down, but if it was me i'd get some AA arsenals, fi q's, crystal compx, dd 3500, just to name a few all would be as good if not better than the mx's but cost a lot less.
Username: Basshead86 Try Google
Post Number: 8025 Registered: Aug-05
Wednesday, November 01, 2006 - 05:00 GMT apples to oranges. the L5's are SPL subs, and the MX's are SQ subs that get relatively loud as hell. MX has a 4" VC, and a Neodymium magnet. they sound better than the XXX and have more output than the SX iirc.
Alabama
U.S.
Post Number: 9721 Registered: Jul-05
Wednesday, November 01, 2006 - 05:27 GMT if u can afford the MX...might as well get it. since no one will have them since they cost to much..but if u want something diffrent then do it
Username: Bass__monkey Las Vegas,
Nevada
U.S. of A.
Post Number: 253 Registered: Sep-06
Wednesday, November 01, 2006 - 14:41 GMT save ur money! i feel bad that costs for a woofer will cost an arm an a leg...
Nevada
U.S. of A.
Post Number: 254 Registered: Sep-06
Wednesday, November 01, 2006 - 14:43 GMT oh... i like the sound of the 04' xxx. mx to me sounds just like a really loud "se" to me...
Post Number: 55 Registered: Nov-05
Thursday, November 02, 2006 - 18:31 GMT so if i did get get the 2 12" mx's what would be a good amp or two good amps? im thinking of running an amp to each sub, what are some realatively good amps that dont cost an arm and a leg? and should i get two amps of just one bigger one? which is cheaper?
Post Number: 8145 Registered: Aug-05
Friday, November 03, 2006 - 04:13 GMT i would get 2 Hifonics bxi2006's if you are on a budget, but if you are going to spend the money on 2 MX's...hell, get a Sundown Audio SAZ1500d or an Incriminator Audio IA 20.1 for each
