System Budget...
Username: Culprit
Post Number: 9
OK thank you everyone for the input, here is the deal...since everyone is saying how shitty my L7 is going to sound LoL...My budget is 800$, could i possibly get anything that sounds better than the L7 for this amount that is just as loud? right now i have no wires, no box, no amp, no sub...nothing so that 800$ is for it all. So far here is what I WAS going to do previously.
--> 15" L7 Solo Baric 2ohm - Sub Woofer
--> Hifonics BXi1206d - Amplifier
--> eKo Kable Amp Kit - Install Wires
--> Unknown Box
--> Xplod CDX-GT400 - CD Player
Username: Culprit
Post Number: 10
ALSO, if anyone has msn messenger...add me on there at white_weaver@hotmail.com. Im new to all this and there is alot i would like to learn. right now im just trying to get the best i can for 800$. THanks!
Username: Rovin
Trinidad & T...
Post Number: 9606
NO to that xplode crap - try pioneer/premier/alpine/eclipse
get ur self a 15" Q www.ficaraudio.com .......
Username: Culprit
Post Number: 11
ok say I was to get 2 of those 15" Qs...what kind of amp and box do i need and where can i get them? and do i get a dual 1 or dual 2?
Username: Tjmutlow
Post Number: 3117
chris I sent you a private message
Username: Culprit
Post Number: 14
how can i check my messages? i clicked on check new messages where is showed my name and it wont show any...
Fi AudioBTL
Post Number: 6662
check your email. the email address you used to register to this site.
Username: Tjmutlow
Post Number: 3118
problems to, sending you reg email.
Username: Culprit
Post Number: 16
im talking about my private messages...my private messages don't go to my email...
Fi AudioBTL
Post Number: 6665
go to your account settings and set it up then.
