Bronze Member Username: Nd4spd18Post Number: 59 Registered: Jul-06 | Since my thread disappeared, I'll post this again. I am planning to get 2 DD 3515's and a Rockford Fosgate T30001bd amp. The amp costs $900, so what I want to know is are there any 3200 watt amps out there that are as good or better than the Rockford, for the same price or less. Any suggestions are appreciated, I just want to make sure I am getting the best deal, thanks. |
Gold Member Username: StnorrisIA US Post Number: 1453 Registered: Apr-06 | i dont know of any right now, but im sure you can find somethin cheaper. i bet the massive audio p3000 will put out just as much as that amp, and you could get it for like 700 i think. |
Gold Member Username: Cenus4, 2 0 Post Number: 2361 Registered: Jan-05 | that RF amp is very underrated, i've heared them putting out around 38-3900wrms. |
Gold Member Username: StnorrisIA US Post Number: 1456 Registered: Apr-06 | i always hear those amps are overrated. ive heard that when they do the benching they do like max hold on the amp...not positive though |
Gold Member Username: RovinTrinidad & T... Post Number: 9315 Registered: Jul-05 | soundstream 3500d is around 700 but i would prefer the RF amp ......... |
Bronze Member Username: Nd4spd18Post Number: 61 Registered: Jul-06 | How is the quality of Soundstream amps compared to RF? And do they produce their rated power? |
Gold Member Username: DrsmithMontana USA Post Number: 1275 Registered: Nov-04 | RF p00ps all over the Soundstream in quality, the RF's are way under rated but i think the SS do there rated power |
Bronze Member Username: Nd4spd18Post Number: 62 Registered: Jul-06 | but is Soundstream's quality decent, I mean would that amp be worthy of being paired with DD subs? Also, any other amp suggestions? |
Gold Member Username: DrsmithMontana USA Post Number: 1281 Registered: Nov-04 | i would buy an SS if i needed it, i was just sayin that RF makes some very nice amps and SS just isnt that great, there ok though, go for it i'm sure its a ton cheaper than that RF talk to ben from www.low-hz.com he sells SS and he is a great guy to deal with |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2882 Registered: Dec-05 | i'm with rovin, but you loose some quality. Rockford is better |
Silver Member Username: LoudonPost Number: 594 Registered: Jun-04 | with the right electrical kicker zx2500 will do close to 3000 |
Bronze Member Username: Nd4spd18Post Number: 64 Registered: Jul-06 | Ok, but does anyone know for sure if the SS amps do their rated power? I was reading the specs for the pca3500d and it says "Accepts up to 16VDC power input"; does that mean those power ratings are at 16 volts? |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 350 Registered: Oct-04 | eD |
Gold Member Username: Basshead86Try Google Post Number: 6952 Registered: Aug-05 | LMAO^^^^ i love you man! |
