What wood to use..
Username: Bsman
Sarnia, Ontario Canada
Post Number: 35
what should i use for mi box 3/4 inch MDF or 1/2 inch MDF or should i use a different type of wood?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1620
3/4 MDF
Username: Rovin
Trinidad & T...
Post Number: 9285
use 3/4 inch MDF ....
Username: Bsman
Post Number: 36
Does 3/4 inch MDF relly make that much of a difference from 1/2 inch? i dont see how 1/2 inch would flex very much
Username: James1115
Ct
Post Number: 6715
what subs are you using?
Username: Makmillion
MN United States
Post Number: 1015
Go with 1/2" birch ply, it costs a little more but it's something like 10x stronger than the comparable 1/2" MDF and it weights ALOT less.
Username: Van_man
Boston South, MA
Post Number: 996
3/4 mdf is the way to go. but 1/2 may surfice if your putting in a couple of 10" Sonys
MN United States
Post Number: 1018
Brand doesn't matter^^ .. pressure is what matters, pressure and sub weight. How strong the board is is what you need to know to compare to the subs you're going to use. Go with Birch Ply, it's extremely strong and lightweight, you only need 1/2" Birch Ply and it'll be alot stronger and more durable than MDF.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1099
but it expands and contracts in heat and moisture :-) .. gotta know what your doing with birch.. its a great wood to use but MDF is a lot easier to work with..
Username: James1115
Ct
Post Number: 6716
exactly^ stick with MDF.
Username: Basshead86
Try Google
Post Number: 6788
i agree....MDF...don't be a rebel. lol
Username: Tremor1127
Post Number: 271
yes, mdf, 3/4"... that 1/4 inch makes a BIG difference...
Username: Tweeker
RE AUDIO
Post Number: 536
i used 1" pine wood to build a box about three weeks ago that my dad had laying around it came out same as other boxes dint really hear a difference as to mdf.
Username: 420alldaylong
Post Number: 476
MDF 3/4 all day long
MN United States
Post Number: 1025
I'll build a box out of birch ply, ill be the only one with b@lls enough to do it :-)
Go with MDF, if you're not man enough to rebel! :P
Username: James1115
Ct
Post Number: 6727
go for it dude:-)
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2775
use 1/2inch Balsa wood...
very durable :-)
lol jk.
go with something mentioned above
Try Google
Post Number: 6816
3/4 MDF works FINE..there is no need to dish out money for a different wood that is susceptible to weather just b/c it may be a bit more durable...
Username: Bass__monkey
Las Vegas, Nevada U.S. of A.
Post Number: 156
use half inch metal! j/j :P
