Mustang Help!
Username: Brady_f
Waco, Texas USA
Post Number: 13
Looking for a pair of 12's that will fit in this box. http://www.soundoffaudio.com/item.cfm/id/2204
Budget for subs is around $450. SPL Oriented.
Powered by Hifonics BXi1606
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1028
if your looking for SPL i'd get a different box.. for on prefab boxes are normally not good not to mention that is sealed.. and possibility you could fit 1 15?
but if you want to go that route here are two RE SE 10s.. $318 + shipping
http://cgi.ebay.com/Resonant-Engineering-RE-Audio-SE-12-2006-BNIB-Sub_W0QQitemZ1 60036391206QQihZ006QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If you build your own box or have one built for you I'd definately go ported.. here are two RE SXs .. little over budget. $468 + shipping
http://cgi.ebay.com/Resonant-Engineering-RE-Audio-SX-12-2006-BNIB-Sub_W0QQitemZ1 60036392979QQihZ006QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Frkkevin
Post Number: 1029
if your looking for SPL i'd get a different box.. for on prefab boxes are normally not good not to mention that is sealed.. and possibility you could fit 1 15? I don't see an SPL setup with that box..
Username: Frkkevin
Post Number: 1030
man idk what the deal was with that double post lol.. net did not even show a post.. just page can't be displayed,, whoops :-)
Username: Brady_f
Waco, Texas USA
Post Number: 14
Well, I was planning on getting a HD3 15...that is until I went and looked at the trunk space. Very Dissapointing. I'm pretty sure that a 15 will not fit in it's reccomended enclosure, that is why im looking for a pair of 12's now. I dont know any other route besides the prefab box b/c as you can see it would be a B@#ch to build...Im out of ideas!
So i guess Im just looking for a pair of 12's to put in a shitty prefab box....sigh
Username: Brady_f
Waco, Texas USA
Post Number: 16
btw kevin...I have had no first had experience with any of the RE line, so I have no idea what I would be getting myself into with buying them. Can you tell me how the Se's compare to CVR's...and is there anything else better for the price?
Username: Frkkevin
Post Number: 1033
SEs build quility to the CVRs are a lot better.. SQ they will dominate and SPL.. they would get louder.. you've limited yourself by going sealed especially with a prefab enclosure.. don't expect a great sub to sound great.. install/box is key for a great sounding setup.
go here to check out some videos of the REs..
http://www.realmofexcursion.com/
Username: Brady_f
Waco, Texas USA
Post Number: 17
Do you have any other ideas as far as a box goes then? I have built a few boxes, but nothing like the box that would fit perfect in that weird @ss shaped trunk.
Username: Frkkevin
Post Number: 1035
if you can't build a regular square box then just take your time and figure out the angles.. use that prefab box as an idea and go from there.. either or get a quote for someone to build you a custom box. it would be worth the extra money.
Username: Brady_f
Waco, Texas USA
Post Number: 18
know of anyone in particular that builds custom boxes (i dont think my local shop does)??
Username: Frkkevin
Post Number: 1038
most local car audio shops will..even the car toys does down here not that I'd recommend them. Marshall White builds boxes as well..
marshall_white2004@ yahoo.com
Username: Brady_f
Waco, Texas USA
Post Number: 20
any other suggestions for subs?
Username: Tjmutlow
Post Number: 2890
not all prefab boxes are bad, also is your mustang a convertable, and does it have a mach system in it, if so some of those boxes does not work.
Username: Brady_f
Waco, Texas USA
Post Number: 21
Ty... I have a 2D coupe with a mach system, but not the system with the subs in it...just the Mach 500, only components. U have any suggestions for subs I can put in that box?
Username: Tjmutlow
Post Number: 2892
sent you a pm
Username: Denali_on_22s
Maryville, TN Us
Post Number: 328
what year stang? i had an 05 and they make boxs to fit that side above the wheel. you could base it off that and do 1 12 on each side ported because mine came with 2 10s
Username: Brady_f
Waco, Texas USA
Post Number: 26
i have an 05..and where did you find that box???!!!!
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1314
post of a picture of your trunk
