Which one would you guys go with
Username: Mike17362
Durham, Nc Usa
Post Number: 57
which sub would you go with the massive cw15 or the l715
Username: Noviceinstaller
Here, There
Post Number: 12
the l7 is more pwrfl and costs about the same............
Username: Mike17362
Durham, Nc Usa
Post Number: 58
im not talking about the power im saying which sube would you go with for sound i heard the l7 just get loud and the massive is a sql and it gets low
Here, There
Post Number: 13
its really up 2 u, as far as which 1 u thnk sounds better if ur not just looking 4 loudness.....
Username: Mike17362
Durham, Nc Usa
Post Number: 59
i mean have you heard both subs?
Here, There
Post Number: 14
i own 2 15 l7 and i have heard the cw15s i like my kickers, personally
Here, There
Post Number: 15
the kkr is dual 2 ohm-- so u can run 1 2 or 4 ohms while the cw is 4 ohm so..............
Username: Mike17362
Durham, Nc Usa
Post Number: 60
that is your opion im saying which is the better sub all a round
Here, There
Post Number: 16
if ur looking for power/bass/reliability and still good quality go with the L7
Here, There
Post Number: 17
the L7s are soldiers my friend clipped the hel out of his for a long time then he over powered them n they still work great plus the L7 has like 20% more cone surface area so thats more air being pushed as well as higher wattage and they stay cool
Username: Mike17362
Durham, Nc Usa
Post Number: 61
so basicly your saying allthis about the l7 cause you and your friend have tested them out alot and dont know much about the massive
Here, There
Post Number: 18
well i have heard the cw15s a FEW times but i will admit ive had more experience w/L7s BUT.. the conditions which i heard the cw15s were similar to those of my L7s
Here, There
Post Number: 19
and the L7s sounded better in my opinion
Username: Mike17362
Durham, Nc Usa
Post Number: 62
i can tell it is yours lol
Here, There
Post Number: 20
well........i just called my friend Josh-owner operater-AUDIOMASTERS kendallville IN to ask him and he said that the cw 15s get a "GOOD" rating while the L7s are 5 star...... plus just look at the stats and youll be able tho decide for yourself.
Here, There
Post Number: 21
http://www.massiveaudio.com/broadband/products/subwoofers/competition/cw_boxinst ruction_stg2v1.pdf
(click appropriate pdf)
OR
http://www.kicker.com/06/kicker_home.html
(subs, L7 etc.)
