Speaker wire gauge help.
Username: Kenkenni
Post Number: 31
My subs have been shipped and our on their way.
My question is, what would be the correct size
speaker wire to use for them. Also, the speaker
wire coming out of my terminal cups seems a little on the thin side. Should I change this out
too or will it matter. It's pre soldered in my
pre-fabbed enclosure. For informational purposes
the subs are two MOFO 10s 1000rms/2400watt peak.
Plan on going with the NINe 1 amp or if they are still having problems shipping these out will be going with another amp with similar specs.
Ken.
Username: Drsmith
Montana USA
Post Number: 146
just get 0 gauge so you can upgrade later if you want
Username: Dustin3
Tigard, OR U.S.
Post Number: 3033
lol. 0 awg. haha
if your talking about speaker wire 12-16 awg is fine, IMO 12 is just for looks
Username: Van_man
Boston South, MA
Post Number: 796
12 AWG would be fine, If you can fit 10awg it will be bulletproof. Solder is fine. Its the best connection you can make. Sounds like some nice choices in equipment. Good luck.
Username: Drsmith
Montana USA
Post Number: 147
my bad didnt read it all
