Which would you choose?
Username: Cocizzie
Bakersfield, Cali.
Post Number: 35
i finally got my car out the paint shop,and i took it to the music shop for an estiment for install.l have evreything except the subs which i was getting from him.i was getting two dual 4ohm treo ssi's,but when i went today he had just got in some re-se's 4ohm dvc's.he said i can have either pair for $400.which would you choose?there both 12 inch,the treo is 750wrms and the re is 600wrms per vc.i will be running them of an xx hifonics hercules 2000 wrms @1ohm in a ported box in a 86 monte carlo ss. and how do i post fliccs thank you
Username: Teddy21
Ann Arbor, MI USA
Post Number: 159
I would be careful running the SE's at that much power. They are rated at 600 wrms per sub not VC.
I got one 12 SX and that thing is very loud with only 600 watts going to it. and ive heard that 2 SE's sound very good in a sealed box.
But with your amp the treos could handle more power and im sure that they are very good subs!
Either way both systems will sound very good and you should be happy with either one.
