?? Need help finding cheap ported box for 12" ??
Username: Nvmyboom
Post Number: 31
If u know of any place to buy a cheap box besides ebay please tell me.
Username: Ctmike
Ct.
Post Number: 1092
imo prefab boxes, especially ported, suck. if you can't make one, have someone make one for you.
Username: Nvmyboom
Post Number: 32
well, i really dont see a difference in buying one or making one b/c i will use prob. the same dimensions.
Username: Ctmike
Ct.
Post Number: 1094
up to you. just if you get prefab, i'd stay away from qlogic. i've been told and read reviews saying that there boxes with the plastic ends tend to rattle.
Username: John_wash
Nashville, Tennessee
Post Number: 377
contact Wahl. He'd be glad 2 build you one. http://www.freewebs.com/wahlsboxes/
Username: Basshead86
Google is your Friend, FL
Post Number: 3976
or ATF on www.j.designs.info
remove the . between j.designs:-)
Username: Nvmyboom
Post Number: 33
ok thanks
Username: Nvmyboom
Post Number: 34
What about this box?????
http://cgi.ebay.com/DUAL-TWO-12-SUB-SUBWOOFER-BOX-SLOT-PORTED-VENTED-MDF_W0QQite mZ280008717952QQihZ018QQcategoryZ14945QQrdZ1QQcmdZViewItem
Username: John_wash
Post Number: 378
u dont wanna get that box because its no telling what it is tuned 2. It might be anywhere from 45hz-55hz. R U good with wood work? If u are then it shouldnt take anymore than $40 and a few hours to put a box together.
Username: Nvmyboom
Post Number: 36
Im good with wood work, but dont have the equipement, how about this box?
http://cgi.ebay.com/DUAL-12-PORTED-3-4-MDF-SUB-ENCLOSURE-SUBWOOFER-BOX_W0QQitemZ 190008230306QQihZ009QQcategoryZ14945QQrdZ1QQcmdZViewItem
Username: John_wash
Post Number: 379
not worth it in my opinion. If you want a nice box get Wahl or Atf 2 make it 4 you.
Username: Nvmyboom
Post Number: 37
How much does it cost for one of their boxes?
Username: John_wash
Post Number: 380
not sure. u'll just have 2 see
