Idiot here
Username: Chuckoya
Hamilton, Ontario Canada
Post Number: 16
"Wire the (2) 10's parallel to your (2) Viper 1200.1d at a 2 ohm load, and you got a perfect match. The viper does 800 watts rms at a 2ohm load , and even though these subs are Dual 4 ohm, they can make a 2ohm load wired parallel. So you got yourself a banging system for just about $860 when you wanted to spend 400 a piece for a 10" sub. This system will not let you down. only thing is, def need a alty upgrade if you go this route. Good luck man"
how would i wire the amps up? would i have to run one amp into the other amp, then to the subs?
Username: Troy81
Tavernier, Fl Us
Post Number: 739
wht the he1l r u talking about?
