Box Tuning
Username: Poremski1628
Post Number: 21
I was wondering if there was any way to tell what a ported box is tuned to after it is built?
Username: Matt12490
Benicia, California USA
Post Number: 1143
yes.. is it a slot ported or PVC pipe?
If you can answer some questions then ill figure it out for you.
Post Number: 22
its slot ported
Username: Stnorris
Eldridge, IA US
Post Number: 733
yea what u can do is take the width, length, and the cubic inches of the port, and use a calculator, to find out what it is tuned to.
Post Number: 24
|\/|aTT |F what else would you need im not sure how to use the calculator
