Over $200!!1
Username: Zulkir
U.S.A.
Post Number: 90
i called the orion dealer and they want over 200 to fix my 1200d and i payed that to get it lol...so i think ima drop down to 1 12 for now with a new amp. then get a second amp to power my other one later..anyone have any ideas on a amp? to power 1 type-r?
Username: Dustin3
Tigard, Or U.S.
Post Number: 2090
dam. thats alot. wait... so wut r u doin with the 1200d, if you plan on gettin a new amp for the tpe-r and then another amp for the other?
jl 500/1
kicker 600.1
alpine 605
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1141
go with hifonics 1206d, don't you think?
Username: Dustin3
Tigard, Or U.S.
Post Number: 2096
from the way i read it, he is using 1 sub per amp. so 2 subs and 2 amps. so a 1206 on each sub will be a lil much IMO
Username: Juliob
Post Number: 1146
try getting one amp for you type R dude, is much better, less wires around jeje. Plus for the money you spend on kicker, JL, you can get the Hifo i'm talking about and wire it at 1 ohm.
Username: Juliob
Post Number: 1147
you have 2 dual 4 ohm subs right?
Username: Dustin3
Tigard, Or U.S.
Post Number: 2111
juliob + hifonics = love
Username: Dustin3
Tigard, Or U.S.
Post Number: 2112
lol
Username: Juliob
Post Number: 1150
i love good, cheap stuff jeje, i like good deals bassman jeje
Username: Dustin3
Tigard, Or U.S.
Post Number: 2116
lol. me too. a8000t, a8002t and hifonics 1206 are my favs . lol
Username: Themax99se
Post Number: 32
what is jeje? hehe HAHA!
Username: Dustin3
Tigard, Or U.S.
Post Number: 2120
lol. its his way of sayin haha
Username: Zulkir
U.S.A.
Post Number: 91
ya i have 2 4ohm dvc subs..had the orion 1200d pushing them and then it just quit one day so i fixed the fuses and rehocked power and it started to smoke..so i called and they want over 200 to fix but it still sels for about 500 it and i only payed 200 for it. so i dont think it would be worth it geting it fixed.what u all think?..anyways.. i am looking for higher end amps like orion kicker jl if i keep my subs..i was think i my sell my subs and drop to 2 12 400 rms subs..haven 2 500 drowns everything out and kills my alt..cant even turn it past vol 40 and that is with everything at the lowest setting. the bigest ho alt i can get for my car is 250 i think. adn it deeds liek a 350+ to run my car adn the subs.what do u all think? i should do?
