OT- batteries
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 469
i think i need to upgrade my battery but i was wondering which way to go. my current one has 690 cca and i was thinking about getting one with 850 cca. or i could get a second battery to power my sub. i run about 1000wrms on a 75/105 amp alternator, stock. which way would be best.
Username: Theweasel
Post Number: 470
oh and right now i don't have any dimming but i still need to hook up another 200-250w to the current 900w.
Los Angeles, CA USA
Post Number: 4195
just get a yellow top under the hood
Username: Teddy21
Ann Arbor, MI USA
Post Number: 134
Dont look at the cold cranking amps, this is only for starting the car, you need a deep cell Optima yellow top.
These battieries can be discharged and recharged without hurting you battery, unlike normal batteries. Sears sells them and they have a good warranty on 'em if they ever go bad.
