Username: Alex_f Near lexington,
Ky
Us
Post Number: 953 Registered: Nov-05
Sunday, June 11, 2006 - 01:40 GMT I have seen it done a few times, so i figure i owuld try it. I sprayed my ported eclipse box with bedliner spray. Then i painted it metallic blue. It looks awsome, except that i free handed it when i cut it so it's a little mis shapped. I'll have pics tomarrow when its sunny.
Username: Livin_loud Ny
Post Number: 222 Registered: Jan-06
Sunday, June 11, 2006 - 04:48 GMT So I got some questions on the bedliner spray deal. Where do you get it? How much? Is it hard to do?
Username: Panocha Post Number: 200 Registered: Jun-05
Sunday, June 11, 2006 - 07:40 GMT isnt bed liner expensive?
Ky
Us
Post Number: 955 Registered: Nov-05
Sunday, June 11, 2006 - 13:23 GMT Well, its about the same amount as adhesive. I got it for $8.50 a bottle, and used 1.5 bottles. I still got some left. Then i painted over it.
Username: Jeepgc Post Number: 13 Registered: May-06
Sunday, June 11, 2006 - 16:15 GMT Where do you find bedliner spray at?
Ky
Us
Post Number: 957 Registered: Nov-05
Sunday, June 11, 2006 - 17:22 GMT autozone, oreily's, etc.
Post Number: 231 Registered: Jan-06
Sunday, June 11, 2006 - 18:07 GMT What did you use to apply it?
Ky
Us
Post Number: 958 Registered: Nov-05
Sunday, June 11, 2006 - 18:14 GMT its spray on.
Post Number: 232 Registered: Jan-06
Sunday, June 11, 2006 - 18:20 GMT Ok thanks. This sounds a lot easier than I thought it would be
Ky
Us
Post Number: 968 Registered: Nov-05
Sunday, June 11, 2006 - 21:06 GMT The only thing is all the wood has to be cut perfect because, unlike carpet, it shows mistakes.
