Help with bridging?
Username: Rollout4877
Kent, Ohio USA
Post Number: 58
i have a 1 ohm stable amp with two channels and 2 dvc 2 ohm subs. is this how i would bridge it?
http://img524.imageshack.us/img524/1232/1ohmbridged4dz.jpg
Kent, Ohio USA
Post Number: 60
anyone?
Kent, Ohio USA
Post Number: 62
bump
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2033
bridging inputs should be marked on the amp. if not, refer to the manual. you'll use one + and one - from each channel, but not every amp is the same. my Zapco REF 750.2 uses the center inputs for bridging.
Stockbridge, GA USA
Post Number: 2034
also, when you bridge an amp, they will not be stable below either 2 or 4 ohms. most are 4 ohm stable, but there are a couple that'll work at 2 ohms bridged.
Kent, Ohio USA
Post Number: 65
whats stable mean. are u saying i need my subs wired at 2 ohms to bridge my amp?
Username: Nypdlapd
Ontario Canada
Post Number: 391
^^^CORRECT>>>>>>> you answered your own question.......LOL
Kent, Ohio USA
Post Number: 66
even if my amp is 1 ohm stable?
Stockbridge, GA USA
Post Number: 2043
is it one ohm stable when bridged though??
