M A audio?
Username: Hockeyknight
Post Number: 125
anyone know how ma audio amps are??? im lookin for a cheap amp that gets about 800 rms and i found this...http://cgi.ebay.com/MA-AUDIO-HK800-800w-RMS-CAR-AMPLIFIER-AMP-FAN-HK-800D_W0QQit emZ9719104537QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if not that one how bout a audiobahn...
http://cgi.ebay.com/Audiobahn-A8000T-Intake-Mono-Block-1600W-Chrome-Amp-NEW_W0QQ itemZ9719066951QQcategoryZ64571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
do either of these accually put out what they say....??? thanks
Post Number: 129
dose any1 know about any other cheap amps that have 800 rms
Username: _jay_
Post Number: 80
hmm that ma audio is a referb...and audiobahn isn't that great of a choice..not the worst but close, i would try looking into hifonics....there amps r cheap and u get quite a bit for ur buck...not lyke audiobahn n' be over rated..n' other off brands..but i need 2 know either ur subs 2ohm or 4ohm n' wut voice coil..? but without that i could still give u a hifonics amp ...go 2 ebay put this in the search box 9719609730...that is the item number
-JaY
Username: Juliob
Santo DomingoDominican Re...
Post Number: 572
problem with MA is that their stuff are rated at 17 volts, you will need a good electrical upgrade to achieve that, their high end stuff is good, go with hifonics yeah
Username: Juliob
Post Number: 573
that audiobahn is great, you will get 800 rms for real
Username: Adddisorder
West palm, Florida
Post Number: 208
yeah audiobahn does put out its power
