Silver Member Username: HockeyknightPost Number: 117 Registered: Apr-06 | im getting 2 cvr's and i dont know what amp i should get... i wans somthin kinda cheap like 150. that would be ideal. any suggestions |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 266 Registered: Feb-06 | 2 audiobahn 800s |
Silver Member Username: HockeyknightPost Number: 118 Registered: Apr-06 | where can i get 1 |
Silver Member Username: Killer44Ontario Canada Post Number: 514 Registered: Dec-04 | what are ur voice coil configurations? |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 710 Registered: Jan-05 | Audiobahn A8000t You should only need one. The cvr is 400rms. It will only work if the CVR's are dual 2 ohm or single 4 ohm. 800rms @ 2ohms. http://www.caraudiodeals.com/product_info.php?products_id=47&gclid=CPWAg7n64YQCF SVLSgodz1B5lg |
