What speakers should I replace and put an amp on????
Username: Pike110
Post Number: 84
I have a set of polk 6 1/2 comp. sr6500's. I was going to run these with a kicker kx550.2 amp. I am putting them in a 2000 s-10 extended cab. The factor speakers are 4x6's on the dash, 6 1/2 doors, and 6 1/2 in the rear from factory. I am going for high sq. How would I go about doing this? I am already replacing the door 6.5's with the polks, but should I replace the 4x6's with high end speakers and run them on an amp also? And what should I do with the 6.5's in the rearfill? Please help!!
Username: Pike110
Post Number: 88
anybody? anybody?
Username: Tjmutlow
Post Number: 2183
yes replace the 4x6s and if your running any type of sub opr subs, forget about rear. use that amp on both dash and components. try to match the 4x6 with polk, some companies make a component 4x6 plate.
Username: Pike110
Post Number: 89
cool that answers it. Thanks ty
