Ascencant Arsenal subs
Username: Winterfreshpimp
Chisago, MN America
Post Number: 20
Thinking about buying 2-12" Aresenal subs, dose anyone have them? are they good? what kind of amp should i get? (not kicker! cant afford them...)
Username: Nnnnick_b
Nc Usa
Post Number: 437
i just posted in your other thread. would you be interested in my amp. 180 shiped. two 12" arsenals @ 4 ohms a piece would place a 2 ohm load on my amp and give them each around 350rms which would be perfect. If not good luck! : )
Username: Nnnnick_b
Nc Usa
Post Number: 438
check out the Orion 600d on ebay, around 220 shipped.
or a kicker kx400.1 180 shipped, that would give them the power reccomended by AA
Both are brandnew instead my used one. Only advantage.
Username: Nnnnick_b
Nc Usa
Post Number: 439
Or an Audiobahn A8000T - 800rms @ 2ohms
I have heard that this is a decent amp.(but its still Audiobahn) 140 shipped. Prob over rated too.
Chisago, MN America
Post Number: 24
arent they 500watts rms?....
Username: Nnnnick_b
Nc Usa
Post Number: 440
are what 500rms?
Username: Nnnnick_b
Nc Usa
Post Number: 441
WOW
I am retarded, you said arsenal, i read assasin.
Username: Nnnnick_b
Nc Usa
Post Number: 442
damn, they are acttually 750 rms. Dual 4ohm.
A kicker kx1200.1 would work well. If you want something inexspensive then possibly hifonics, but i would save for the proper amp.
Username: Nnnnick_b
Nc Usa
Post Number: 444
Check out the Orion 1200d as well. Good luck.
Chisago, MN America
Post Number: 26
naw nick its all "g" your actually trying to help thats tight. thanx to every one else too
Chisago, MN America
Post Number: 27
should i buy a stronger hifonics? are they under rated?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1276
Hifonics are overrated so don't expect to see thoes full ratings.
the Arsenals have been getting good reviews. even read comments saying they sound a lot better then the RE SX's which are suppose to be comparable.
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1418
If they're louder and sound better than the Assassins, you're in for a real treat!
Chisago, MN America
Post Number: 34
ok thanks all!
Los Angeles, CA USA
Post Number: 2998
the arsenals can easily handle 1000wrms a piece. i was kinda interested in those subs before so i asked chad at ascendant audio. he told me he underrates his subs so it can handle alot more than its rated rms.
Chisago, MN America
Post Number: 42
reccomend and amp? i was thinking the soundstream 2000d picasso
Los Angeles, CA USA
Post Number: 3001
i don't know much about soundstream amps so i couldn't tell you if that amp is a good choice. i'd say though go with an amp that can put out 1200wrms and kinda go easy with the gain for a daily driver. that way if you ever want to see what kinda number it can hit you can always adjust the gain to utilize the full 1200wrms and crank it up. according to chad at AA, the arsenals can easily handle twice as much rms then the rated rms.
Username: Jron
Post Number: 207
just got mine in yesterday can't wait to hear it.
Wellsburg, WV USA
Post Number: 1421
"he told me he underrates his subs so it can handle alot more than its rated rms."
Ok, he told me that he rates his subs in such a way that users will have them around "forever" so to speak.
I believe you about the handling a lot more power, but why would he tell me something different than you? I asked him if the new line was capable of handling more power than what is listed on the spec sheet...
