Clif Designs
Username: Bad_azz_bowtie
Post Number: 13
How are these subs...i've got a friend that found some on the net that he likes..but i dont know anything bout them...thx yall
Post Number: 14
or maybe not.......
Username: Greeney1888
Maple Grove, MN United States
Post Number: 218
pics/link of them?
Post Number: 15
http://www.sonicelectronix.com/item_3744.html
Post Number: 16
Product Description:
12" Competition SPL Subwoofer
RMS Power Handling: 600 watts
Peak Power Handling: 1200 watts
Dual 2-Ohm Voice Coils
PVA Treated Pulp Cone
Aluminum Dust Cap
Treated Foam Suround
Flat Progressive Laminted Spider
Hyper-Extended Pole Piece
Vented Bumped Back Plate
Die Cast Aluminum Basket
Aluminum Trim Ring
5-year Authorized Manufacturer's Warranty
Subwoofer Specifications:
Subwoofer Size 12"
Impedance 2 ohms
Dual Voice Coil Yes
Peak Power Handling 1200 watts
RMS Power Handling 600 watts
Woofer Surround Foam
Woofer Composition N/A
Sealed Box Volume 1.75 cu. ft.
Ported Box Volume 3.5 cu. ft.
Sensitivity 88.7 dB
Frequency Response N/A
Xmax (millimeters) N/A
Top Mount Depth 8"
Cutout Diameter N/A
Warranty 5-year Authorized Manufacturer's
Username: N2audio
Lawrence, Ks USA
Post Number: 713
audiobahn-ish
Username: Loc_out
Santa Ana, Ca
Post Number: 328
I wouldnt buy it 300 bucks come on men... You can get a better sub for 300.
