Ricky Green
Monday, February 13, 2006 - 06:05 GMT What would be the best amp to power 2 Alpine Type R's?....I kinda want to overpower them too....i've heard with a good box they can take a lot more than 500rms.......Thanks.
Alabama
U.S.
Post Number: 5375 Registered: Jul-05
Monday, February 13, 2006 - 06:07 GMT Any amp that puts out around 1500 rms
Ricky Green
Monday, February 13, 2006 - 06:23 GMT I was thinkin of these amps....which would be best? JL 1000/1 Orion 1200D Kicker KX1200.1 any other suggestions would be good to.....Thanks
Username: Dlc_killzone Post Number: 4 Registered: Feb-06
Monday, February 13, 2006 - 06:25 GMT Any amp in a 1000 dola mark or higher lmao
Username: James1115 Ct
Post Number: 5022 Registered: Dec-04
Monday, February 13, 2006 - 06:28 GMT in order 1)jl 1000/1 2)Kicker 1200.1(although its more of the power you need) 3orion 1200.1
Alabama
U.S.
Post Number: 5379 Registered: Jul-05
Monday, February 13, 2006 - 06:33 GMT Ampman Revolution 1500.1 1500 @1 ohm at 12.6 volts
Username: Grat81 Carbondale,
IL
Post Number: 65 Registered: Dec-05
Monday, February 13, 2006 - 06:35 GMT a cheapie but goodie -- jbl BP1200.1 can get 'em used on ebay for around $250 i have two of them on my X's and they sound pretty sweet the newer JBL amps with the crown power are pretty killer, too. -G
Alabama
U.S.
Post Number: 5381 Registered: Jul-05
Monday, February 13, 2006 - 06:36 GMT viper 1200.1 is only 125 and it puts out its rated power
Derek Martin
Monday, February 13, 2006 - 21:10 GMT u should pick between either the jl or the kicker
Username: Efil4zaggin Chi Town,
IL
Cook
Post Number: 143 Registered: Dec-05
Monday, February 13, 2006 - 21:47 GMT "viper 1200.1 is only 125 and it puts out its rated power" so Y is it so cheep then
Alabama
U.S.
Post Number: 5389 Registered: Jul-05
Tuesday, February 14, 2006 - 00:58 GMT because its disconinted Same company makes orion, and dei(directed)
