Bronze Member Username: Darkale85Averil park , Ny Renn Post Number: 69 Registered: Jan-06 | what kind of amp should i get for these two subs i was looking to spend no more than 100 bucks thanks |
Bronze Member Username: PanochaPost Number: 21 Registered: Jun-05 | if yo only have 100 bucks look at ikesound.com they have alot of refurb but still good you only need around a 300-350 watt amp. |
Bronze Member Username: Darkale85Averil park , Ny Renn Post Number: 70 Registered: Jan-06 | well i have a 300 watt 4 ohm amp but i was looking to run like 125 rms to them but thanks for the suggestion |
Gold Member Username: TjmutlowPost Number: 1436 Registered: Sep-05 | what voice coil and ohm are they. |
Bronze Member Username: Teddy21Ann Arbor, MI USA Post Number: 22 Registered: Feb-06 | i had some of those but they were 10 inches I ran them with a older ppi amp it was rated at 240 watts 2 channel and was perfect for those. here is one like it but i used the 2240 model http://cgi.ebay.com/PRECISION-POWER-PPI-Amp-Amplifier-PC275_W0QQitemZ5864027410Q QcategoryZ18796QQrdZ1QQcmdZViewItem |
Bronze Member Username: Darkale85Averil park , Ny Renn Post Number: 72 Registered: Jan-06 | funny enough i have that same amp how should i run it bridged or what? |
