Good dummy load, right?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1776
http://cgi.ebay.com/RESISTORS-0-05-OHM-105-WATT-RESISTOR-15_W0QQitemZ2564150369Q QcategoryZ4664QQrdZ1QQcmdZViewItem
with those i could wire multiple resistors in parallel/series and get w/e ohm load im looking for and tune amps up to 1500w rms correct?
thanks guys, 'preciate it
Los Angeles, CA USA
Post Number: 2342
since they are 105 watt resistors wouldn't it take away that much power from your amp? i am assuming you would need to use at least two of those so that means 210 watts. just a thought i have. i am probably wrong.
Post Number: 1778
i thought the 105w meant they can handle thermally 105w rms....
Username: Blainew
Post Number: 931
those are only .05 ohms ...wouldnt you need alot more than 15 of them
Los Angeles, CA USA
Post Number: 2347
oh my bad i was thinking .5 ohms each.
Username: B101
Queen City, NC USA
Post Number: 1026
Trevor Im not sure what you asking. Do you want to simply drop the ohm load of the sub for more output of the amplifier? Or do you just want to measure the power coming out of the amplifer?
If its to gain more power it wont work, cause the extra power will be disapated across the resistor in the form of heat. You will need a transformer in this case. =D
Post Number: 1783
i want to do this for example.
hook a 200w 1 ohm stable amplifier up to 2 of them wired in series for a 1ohm load. then adjust the gain while playing a 50z tone at 3/4 volume and turn the gain up until i reach appx 14V from the speaker outputs....
so to tune an amp
Username: Blainew
Post Number: 932
trevor those resistors are .05 ohms not .5 you would only get a .1 ohm load....not a 1 ohm load
Post Number: 1786
wow the whole time i was reading that the "zero" after the decimal was invisible to me lol. i feel dumb... well say for instance they were .5 ohm or 2 ohm for that matter. would they serve my purpose?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 617
that resistor is a wire-wound resistor. just get you some copper wire and roll it up until it equals one ohm.
Username: Safe_cracker
Chicago, IL US
Post Number: 150
http://cgi.ebay.com/Resistor-2-ohm-50watt-1-Dale-Resistors-20_W0QQitemZ758798825 5QQcategoryZ4664QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 1787
lucas, but then how do you know how many watts it can handle?
Username: B101
Queen City, NC USA
Post Number: 1028
Trevor try this, it may help.
http://sound.westhost.com/tsp.htm
http://www.diysubwoofers.org/measure.htm
