Revised system ne good?
Username: Killer44
Ontario Canada
Post Number: 351
ok so i already got 2 12inch kicker compvr dual 2ohm(gunna run them at 2 0hms), a pioneer gm3100t(60x2@4ohms) for my 6x9's,4gauge wiring kit...
i still have to buy an alpine cda-9851(is it ne good, was going to get 9855 or 9853 but dont want to spend that much), an Audiobahn A800T(for my subs), Some jvc 6x9's im getting for cheap off a friend, and have to build a sealed box for them al going in my 1987 s10 reg cab.
So how will the system sound? im giong more for spl, and will only one set of 6.9's in the dash running of the amp be enough, or will the subs drown out the vocals? And lasty does ne one think i will have to get an HO alt? thanx in advance
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1686
that should be plenty loud man
Username: Killer44
Ontario Canada
Post Number: 352
thanx alot dane so i should be fine with only one set of 6.9's? and u know nething bout the HO ALT?
Username: 54danny54
Post Number: 1688
u shouldnt need a HO alt because thats no more than 900 watts...but if it starts 2 dim then id get an alt or new battery
Username: Killer44
Ontario Canada
Post Number: 353
thanx for all the help man...
