hi can you help ive got 2,4channel amps and 4,2 channel amps but not no how to wire up the r.c leads do i daisy-chain the leads to each amps or do i get r.c splites, please help!!!!!!thanks
what i mean is the rca leads that you use to wire up the amp not remote lead. how do i connect up 6 amps when i only have 2 rca leads that come from the head unit. do i go into the input with the rca lead then come out of the output into the input on the other amp and so on
