how are orion amps? I'm looking at the 4002. it's 100 x 2 @ 4 ohms and 200 x2 @ 2 ohms. I will be useing it to run 4 infinity perfect 6.1 components. thanks
orion amps are pretty good still. their older ones were better, but the ones out now are still good. if thoes comps are the 4 ohm ones then that should be fine, but 200 watts will be too much if they are the 2 ohm versions.
