The new brahma
Username: Blainew
Post Number: 817
has it come out yet....the mark 2 or something like taht?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1996
yea...they are out, in limited numbers.
(brahma MKIII's....600wrms, 2.5" coils)
i'll get a link for ya.
gimme a sec.
Username: James1115
Wilton, Ct
Post Number: 4771
yup its out but itys the mark III tha mark II was the last version.
Post Number: 1997
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/adire_brahm a/
10's---$319
12's---$349
15's---$379
2.5" coils, 600wrms, 28.5mm xmax...IMO, thats a pretty darn good price for an super SQ sub. the new MKIII's have a lower inductance than the MKII's. (my MKII 10" cost me $369 in 2004, it was an amazing sub)
Username: Blainew
Post Number: 818
only 600 wrms??
Username: James1115
Wilton, Ct
Post Number: 4773
yup www.adireaudio.com 28.8mm one way x-max lol
Post Number: 1998
yes...600wrms, the new MKIII brahma's are supposed to be really efficient.
the MKII's were rated for 1600wrms, but they didnt nearly need that much to get moving. ~600wrms for the MKII 10" was plenty. that 1600w rating was just the thermal rating of the coil.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2087
the handling is the same as the previous model. as marshall stated, the new models are based on a rating system more standard to car audio and not pro audio & others (IEC 268-5) as was the previous model.
however, adire has always maintained that the power handling would be enclosure based, and even the recent 600w estimate is just that (an estimate). i would place the practical range in the same 600-800w region. i failed horribly at running mine off of 1600/sub because i thought i had no choice. handling was suggested by adire to be just fine in .75cuft.
needless to say i'm expecting mine back from recone this week. found out that my soundstreams are 2ohm stable after all. so i can use just one of my amps to put 900 to each sub no prob. and no need to run the 1600 from each amp.
Post Number: 2003
mikechec,
just a guess on why you got a recone...but did your spiders pull away from the frame?
Username: Mikechec9
Post Number: 2088
the glue gave way. vc turned into a slinky. suffice it to say, adire corrected that issue too with their new line.
it's just taking an eternity to get them back.
Username: Mikechec9
Post Number: 2089
Username: Alteraudiousa
Concord
Post Number: 90
I believe adire was rating their subs at mechanical while now its thermal or is it the other way around....i can't think, this stupid cold.
Username: Mikechec9
Post Number: 2090
it was thermal then, and now it's mechanical.
http://www.easy-audio.com/tech/BrahmaOwnersGuide.pdf
