This all i need?
Username: Thigpen
RVA, Va Usa
Post Number: 412
http://www.edesignaudio.com/wire_product.php?productid=242
is that all i need for my big 3 wiring upgrade in my 3000GT?
and since im goin to be putting a re 12.1 on my stock alt should i upgrade my battery? if so where should i get it and what kind of battery?
Username: Thigpen
RVA, Va Usa
Post Number: 413
bump
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 868
changing your batter wont do much.. you will need a more powerful alternator.. that kit should be fine.. probably be easier to just buy stretch of wire and cut want u need.. if u do get the kit measure under the hood to make sure it will be long enough
