Bronze Member Username: Steven1234Rahway, NJ Post Number: 91 Registered: Nov-05 | im going with SQ i have 2 12inch diamond audio D6's in a ported box. should i go with a D6 1000.1,a memphis 16-mcd1000d or a crossfire VR1000d |
Gold Member Username: RovinTrinidad & T... Post Number: 5060 Registered: Jul-05 | D6 subs r rated @ 600wrms - so why r u looking @ 1000wrms amps ?????... maybe a orion/kicker 1200 amp should be good .... |
Silver Member Username: B101Queen City, NC USA Post Number: 714 Registered: Sep-05 | rovin.. polident thread. |
Bronze Member Username: Steven1234Rahway, NJ Post Number: 92 Registered: Nov-05 | how about the d5 1200.1 or how about some other ideas for amps that allow 1200 watts at one ohm. |
Gold Member Username: RovinTrinidad & T... Post Number: 5064 Registered: Jul-05 | "d5 1200.1" - whats that , an older model ? the orion/kicker 1200 is 1ohm stable Also if u really want good SQ then use a sealed box instead.... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1111 Registered: Dec-05 | www.cardomain.com , orion amps are half off |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1112 Registered: Dec-05 | and yeah like rovin said for sq stick them in a sealed box |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1113 Registered: Dec-05 | and even then if you dont like it you could keep the ported and go back to it |
Bronze Member Username: Do_em_dirty816Kansas City, MO USA Post Number: 51 Registered: Jan-06 | Yea what Rovin said if you're looking for sq go selaed rather than ported... Also the kicker kx 1200.1, the orion 1200d, and if youre on a budget the HIFONICS BX1205D might work (but you never know what you're gonna get out of hifonics). |
Bronze Member Username: Do_em_dirty816Kansas City, MO USA Post Number: 52 Registered: Jan-06 | lol sorry 4 the repeat of the same thing we must of posted at the same time. |
