Looking for a good 6" sub
I'm not very knowledgable to subs, but I would like to keep it small and affordable. I only know of JL making a 6" sub, but I do not know anything about it. Can anyone recommend any 6" subs?
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 472
well, u should try www.partsexpress.com . i just ordered sum stuff from there. look at dayton audio
Username: 54danny54
Betsy layne, Kentucky.. USA duh
Post Number: 1426
that same sight...alex is right
look at Tangband, and Dayton
wat u get alex
Username: 54danny54
Post Number: 1428
tangband makes great small woofers from wat hear...ask sean
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-832
how's that one look
Username: 54danny54
Post Number: 1433
get it ...y dont u get a bigger 1?
need the space, save money, don't need a monster bumpin' system
Username: James1115
Wilton, Ct
Post Number: 4515
the new 6 in woofer from ascendant audio looks like it would be a great small sub set up. 22mm xsus in a 6.5 lol
Username: Insearchofbass
Post Number: 4105
that tangband will fit in a 6 inch hole and trust me it will suprise you in output....the tangband that is...thats the ones i have....and they dont need tons of power but they can take more than they are rated
Post Number: 4106
i had 280 rms two two of them in my abc box and they are only rated 60 rms each....and that was on music
Post Number: 4107
james wheres that ascendant audio 6.5 i cant find it
Post Number: 4108
anon let me know how you like it when its done
