Audiobahn subs
Username: Berns231
Post Number: 8
i was thinking about buying 2 audiobahn aw1200n subs off ebay for like 117 bucks. there dvc 4 ohm subs 700 rms each. It sounds to good to be true. Any opinions on the quality of these for the price. Or does anyone else have suggestions for 2 subs to buy for under $300 that are over 600w rms for total for both of them. Thanks
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 385
get 2 12' alpine type Rs. ull be ALOT happier.
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 287
THose Audiobahns will hit REALLY hard and be loud if you feed them enough power but wont have much SQ that is just how audiobahn subs are!
Username: Lexuscoop
Post Number: 487
so are audiobahn ment for SPL or... what?
Username: Sploosh56
Ohio
Post Number: 1011
audiobahn subs never last for long. yes they can get loud but that's it. they sound horrible.
Username: John_wash
Nashville, Tennessee
Post Number: 22
where ya been at wahl
Paulding, Ohio USA
Post Number: 290
ya they are more of a SPL subwoofer then a SQ sub
Los Angeles, CA USA
Post Number: 1554
i used to have audiobahn 1208t and that thing sounded bad. it did get loud but the bass would hit behind the beat of the music on some trance songs. i thought i might have connected wrong but i double checked all the wiring and it was correct.
