Need help with 05 Silverado install
chevsilv05
Im trying to put a couple of subs under the back seat (ext. cab) and I have about 600 watts rms to work with. I need as much spl as possible. thanx
Username: Lexuscoop
Post Number: 270
your best bet, it to make your box your seets... sounds wierd, but my buddy did it, make the box ported and you should be good, depending on the box and the subs
