Silver Member Username: Safa19Post Number: 175 Registered: Apr-05 | when it comes out of the possitive outlet and then splits to the first speaker and then keeps going to the next one, how would that be wired? like just split the coating over the wire? which doesnt seem right... or does it mean run 2 wires from the positive terminal one to each speaker? |
Silver Member Username: TjmutlowPost Number: 338 Registered: Sep-05 | it shows how to wire single 4ohm speakers down to a 2ohm load |
Silver Member Username: Safa19Post Number: 176 Registered: Apr-05 | thats not what i meant, did you read what i wrote underneath it cause anyone can tell thats what it means... where do the wires actually go? i mean the wire doesnt just have another wire coming off if it |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 30 Registered: Aug-05 | This is how I do series... |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 31 Registered: Aug-05 | Parallel *** |
Silver Member Username: SolacedagonyNew Jersey US Post Number: 693 Registered: Oct-04 | Yea there ya go. I have my 4 ohm DVC sub wired like that to 2 ohms. |
Silver Member Username: TjmutlowPost Number: 342 Registered: Sep-05 | you have to run seperate wires, just think about it splitting the end would not work, not lonk enough!!! you need 4 wires.... |
Al J Unregistered guest | Bought a Sony Xplod sub and amp second hand and so have no wiring guide, does anyone know of any free wiring schematic diagrams avail. on the net?? |
Silver Member Username: Safa19Post Number: 182 Registered: Apr-05 | thanks tyler for the redraw but since i am running the left side speakers togeather and the right side speakers togeather, would what tyler drew be the same as just running to wires from the terminals? and also what guage wire do i need for speakers? like 8 guage? |
Gold Member Username: RovinTrinidad & T... Post Number: 3732 Registered: Jul-05 | http://wickedcases.com/caraudio/speakerpwr.html but i'm gonna use 10G 4 my 2 Rs - couldn't hurt none ..lol....... |
Gold Member Username: RovinTrinidad & T... Post Number: 3733 Registered: Jul-05 | http://wickedcases.com/caraudio/wire.html but i'm gonna use 10G 4 my 2 Rs - couldn't hurt none ..lol....... |
Gold Member Username: RovinTrinidad & T... Post Number: 3734 Registered: Jul-05 | 1st link was the wrong link i posted by mistake ... |
Silver Member Username: Safa19Post Number: 184 Registered: Apr-05 | wouldnt using 10g not be enough at all cause that would be 1000watts 10guage isnt enough for that or do you mean use 10g for the amp to the subs? |
