Subwoofer enclosure for RE SX 12''
Username: Fmxkid003
Post Number: 8
im am looking to build/buy a ported enclosure for the RE SX 12'' sub the max width of the enclosure must be 30'' because my trunk cant fit anything wider. does anyone know of a configurator for the sub box or any reccomended box dimensions?
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 159
i could build u a very nice box,cheaper than it would be too have it made by a audio shop
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 272
check out www.bcae1.com for a sub box calculator. i believe its like number 110 on the right side. or go to www.klausaudio.com who could build you a custom box, and while ordering, you can put in a parameter, like 30" max width and they will tell you height and depth for a specific volume. just play around with some numbers and see what you like. the recommended enclosure for it is 1.9 tuned to 32Hz. thats what i have and love it.
