Amps and volts/car amps
How many amps and volts do car amps need to run properly at max power.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1741
http://caraudiomag.com/specialfeatures/0111cae_anatomy/
read "power supply"
it doesnt say how much amperes and volts a car amp needs to operate at full power properly.
Username: Karam
Post Number: 117
this should help
http://www.the12volt.com/info/recwirsz.asp
Username: Karam
Post Number: 118
the other thing is it varies on every single amp, depends on what amp you have.
