Help me choose a Subwoofer + Amplifier
Username: Grapefruit
Okay.. I have a budget of around $600 dollars for both the sub and the amp.
I've thought of two type-r alpine subs, or a JL W6 sub. Which of the two are better?? I haven't looked into mono amps yet.
Suggestions are welcome also.
a l e x farris
do u want sq or spl
Username: Thigpen
RVA, Va Usa
Post Number: 294
i cant tell you anything about the type r's but i have the exact same budget and im getting 2 RE SE's from the RE group buy for 137 a piece and then a kicker kx1200.1 which runs about 300-350 on ebay.
Los Angeles, CA USA
Post Number: 1096
that is going to sound nice matt. make sure you don't buy the refurbished kx1200.1.
Post Number: 7
I want spl more... I listen to techno/trance. Thanks ill look into those RE SE's.
Username: Phantoms_party
I need help on getting unexpensive Subs that I can hook up under my driver and passanger seets of my truck. I also want them to get loud enough that you can open the doors(crew cab) and have enough music for a party......any sugestions?
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 45
"I need help on getting unexpensive Subs that I can hook up under my driver and passanger seets of my truck. I also want them to get loud enough that you can open the doors(crew cab) and have enough music for a party......any sugestions?"
That would suck.
Username: Young_james
Post Number: 266
^^x2
