Im thinking about buying new subs. Please read
kevin04
right now i have to 12" rockford P1's(8ohm), hooked up to a 800w pioneer amp(a.k.a. p.o.s). if i were to upgrade to P2's would it work still with the weak amp ive got or would it be essential to get a new amp. Or are P2's not even worth it.any suggestions would be great
Username: Rovin
Trinidad & T...
Post Number: 2289
well if its a POS pushing a P1 then it'll be a even bigger smellier POS with a P2
Sell both & upgrade ....
Username: Lanzarchamp
Bakersfield, California United States
Post Number: 223
p2's aren't worth it go for the alpine type r 12's and get a 1000 rms amp and you ll be rolling
kevin04
o.k. so what do u guys think about buying and selling off of ebay for subs?
Post Number: 224
you can get 2 type rs shipped for about 2 hundo off ebay, just gottta buy from the right people
Username: Rovin
Trinidad & T...
Post Number: 2292
how much would u like to spend & is it 1 12" that can fit your ride ?
kevin04
well i plan on spending another $200 on subs and $200 on my amp, but i plan on buying both at different times. So if i were to buy the subs first should i just forget about even hooking them up to the 800w pioneer? if they were alpine type-r 12's.
kevin04
i can fit 2 12's in my car real tight. i have 2 P1's now. sorry forgot to mention that.
Username: Rovin
Trinidad & T...
Post Number: 2294
The 1242 4ohms dvc Rs are a good value for $ - i ordered to for my self
@ that low budget u will have to go ebay & search
Amp - Hifonics BX 1500D is $ is really tight .
U should look for a MB Quart raa1000 , PPI 1000 , Diamond audio D61000 for example but will costs about $350 & up
Los Angeles, CA USA
Post Number: 326
type Rs are nice. they don't require a large cuft enclosure. they sound clean in a nice little sealed enclosure. 2 12" type Rs and a kx1200.1 amp sounds like they are made for each other.
