How loud til you can feel it?
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 176
How many db does it take before you can feel the bass?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1485
well...130dB is pretty much regarded as the "thresh hold of pain".
but as far as bass that REALLY hurts...140dB @35hz would get the job done :-)
Username: Robert_d
MIA, FL USA
Post Number: 295
isnt that kinda hard to get at 35hz ?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 599
idk if this answers your question or not, but my current setup of 2 12inch kicker comps in a ported box tuned to 37hz hits 127db legal on TL, and i can make my rear view mirror fall off playing a 40hz test tone.idk if thats what u call "feeling" the bass but it is pretty funny to watch.
Post Number: 1486
yea, 140dB @ 35hz is pretty dam loud...and i mean pretty DAM loud...lol
127dB knockin off an rearview mirror? (wow, it must not be on there very solid...prolly sounds pretty good though, i have always like CVR's) My rearview mirror will only just barly move w/ 147dB @ 48hz.
Username: 54danny54
Post Number: 935
lol this place has gone down since i been gone yall....
outie for a good while P3@c3
Username: Robert_d
MIA, FL USA
Post Number: 297
depends on the car my camrys rear view is probily the hardest part of the car lol it would be the only part of my car not moving with my bass blowing
my friends ford escort has 2 10"s with a 500 (250 rms i think) mtx amp and it thumps a lil but his rear view falls off all the time
cant wait till a couple months im thinkin of a 18" mt and an orion 2500d
Username: Cenus
Post Number: 600
ya well the suv is pretty old 91 jeep cheroke, and the rear view mirror is just on this sliding thing so its not really glued to the window. and i have the comps not cvrs, pretty much the very bottom of the line subs. but i do have to admit that through all the h3ll i put these subs through they keep on playing.
Username: Fandim
Reno, Nevada United State...
Post Number: 388
Heh.. at about 152ish dB, at 47-48 hz, in a 99 firebird, my rear view mirror has like... a quick type vibrate to it...like a minor blur if you're looking at something behind you etc...
However, not nearly as loud, but at like 25 hZ, everything in my car feels like you're in an earthquake. You'll feel lower frequencies a LOT easier IMO.. Then again, it takes the same amount of power to play those lower frequncies at a lesser volume, than it does the higher ones at way louder.
Seth
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 254
honda it depends more on the fq of the bass not nessecarily the db.
Username: 54danny54
Post Number: 936
but anyways...bass can be felt a not really low but not high volumes...ive felt it in my chest at like 105-110 range lol
