Which section in walmart can you find polyfil
Post Number: 50
i went to walmart to buy polyfill and i couldn't find it.
i asked the person working there and they had no idea what i was talking about.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 722
go to a fabric store then.. its quite common stuff
Username: Nutty91rs
Bloomington, Indiana USA
It's in the arts and crafts section, they have different types as well, just get the cheap stuff it works fine.
Post Number: 63
is it called polyfill?
Username: Nutty91rs
Post Number: 20
Something like that, it's polyester pillow stuffing. It will have pictures of stuffed animals and such on the front, or a green latice work design on a clear bag. The bags look like pillows when you see then, can't miss it.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 454
its in the girls section ......... ha ha ha ha
what is polyfill and what does it do
Username: Nutty91rs
Post Number: 25
People put it inside of there enclosures, it slows down the sound waves inside of the box and "tricks" the sub into thinking it's in a bigger enclosure, it's also supposed to help with standing waves. It can make a sub act like it's an an enclosure that's 10% larger than what it's actually in. Don't go overboard with it though the recommended ammount is something like 1 pound per cubic foot but I usually use half of that or less and fluff it out some so it's not as dense.
